***VISTA SP1 RELEASED TO GENERAL PUBLIC***
So still no word from Microsoft? What happened to the whole 'mid-march' timescale?
This is the same build as the beta I think. This is the beta which I downloaded yesterday.
Can someone who has just installed check what theirs says?
Mine's exactly the same perox.
As mentioned before, its MS Vista Business x64 with SP1 integrated off the MS Volume Licensing services website.
Does it show under "view update history" for you? Mine installed with the package from the torrent doesn't do this, and i can't install languages anymore, so i think i might be better off rolling back and going back to SP1 via windows update?
vista sp1 rc2 = rtm version.
the one you downloaded yesterday from windows updates isn't beta, its the final version.. they just didn't update the information..
yeh dont worry, same happened to me, it'll keep going. same with installing stops at 75% ish for a bit, along with when you restart it, first install on the restart stops at 15% for a bit as well.
yes you heard right. there are about 3 installs till its done :P
Is this a slip up by MS I can’t see why they would be this low key, surly this is a mistake release? What happened to next month’s release date?
