Wait for 5XXX or 7900XTX?
19 Jun 2009
London
I've been patiently waiting to upgrade my RTX3080 but even with the release around the corner I'm not sure I'm happy to pay more than £1k for a new GPU, so just looking at what the red side offers - The 7900XTX.
Current PC Specs:
AMD Ryzen 7 5800X
Corsair 64GB DDR4 3600
RTX 3080
Corsair HX1200 PSU
Samsung 49" G9 -5120x1440p
Mainly play FPS and racing games but want to get more into other genres as I've now got rid of PS5 so PC is my only gaming system and want to play games on Ultra quality.
I'm also waiting to upgrade to AM5 (9800x3d) sometime in the new year when stock is available again but would the 7900XTX be sufficient enough for my needs or are the 5XXX nvidia series expected to be marginally better?
I would wait but also don't discount the 7900XT, I've seen them little as £540 in last month and it's decent for 4K but excellent for 1440p
Paid £900 for my 7900XT 2y ago. Been a great card.
I'd wait until the new gen is out as the current gen is 2y old now and is due to be replaced. Your 3080 is still good too!
With that monitor being so close to 4K and also 240 Hz, you need all the horse power you can get.
I have a 7900 XT which I sometimes use for 4K60 native, and it's fine for that, but sounds like you're going to be wanting to have upscaling turned on whatever GPU you go for, in which case DLSS is far superior to FSR in general. Although your monitor has a total pixel count close to that of a 4K, it looks like the pixel density is about that of 1440p, and the gap in quality between FSR and DLSS is more noticeable at that level than at 4K.
If I were you I'd be holding out for one of the new 5xxx series cards with hopefully plenty of VRAM. If FSR could pull level with DLSS in image quality, then it might be a different story.
Thanks for the feedback fellas, I think the best thing is to wait another month or so.
The question now is, do I upgrade to AM5 :D
I have a similar setup (5800X and RTX3080).
Planning on upgrading to the 7/9800X3D, as that would be a significant upgrade - should also stay relevant for quite some time. Will see what Nvidia announce in Jan; the 5080 will be a decent buy if it's on-par with with 4090.
Yep exactly what I'm keeping an eye out for too.
We're less than a month away from new GPUs targeting your exact budget...
If the 5080 gives same performance of 4090 that's going to be the one I'll be looking to get.
January rolls round...
RTX 5090 - £2,500
RTX 5080 - £1,300
RTX 5070 - £700
No £1,000 GPUs until the 5070 Ti, which launches at £900 later in the year :p
Still going to make a saving versus buying now though.
RTX 5090 - £2,500
RTX 5080 - £1,300
RTX 5070 - £700
"The more you buy, the more you save".
Jensen, is making us do it...The power of his oven.
I would wait a month, then the prices of AMD cards will drop, for example 7900 XTX. You can make a decision on what the reviews of the new tech is in terms of its relative performance.
Depends on how much you think the cost of whole platform upgrade is worth it. You do still have the option of 5800X3D or 5700X3D on AM4 for cheaper CPU upgrade.
But for GPU defo wait. Worst case, you'll just buy end up buying a 7900XTX for current pricing, but at least by waiting you can confidently make a decision.
Funny you mention that I was actually looking at the 5700X3D to replace the 5800X, the switchover would be minimal in £ for me.
Paired with the 3080 at ultrawide 1440p is there going to be a noticeable difference in games like Black Ops 6 / Warzone?
