- 8 Feb 2004
- Dartford, Kent
mightynimrod, what stops any air from floating up into the rad instead of the T line?
Meths said:That's what I'm gonna do.
I've decided to remove the floppy drive along with the 3.5' bay and the rad will fit easily. Then I'll alter the 5.25' bays at the top to take my hard drive and one optical drive. Might even mount a fan in there as well to cool the HDD.
Seems easy enough at the moment.
What should I add to the deionised water once it's going. Is bog standard anti freeze okay or will I need some inhibitor to prevent rust as well?
SidewinderINC said:mightynimrod, what stops any air from floating up into the rad instead of the T line?
weescott said:What the heck is that Mike? Looks very old skool.
Tim said:Whats the join between pump and rad?
it all needs redoing tbh without the stepdowns and a relocation of the pump.
) on the barbs that worked fine too..
Can I ask how you guys drain the system with fillports like that?
