Watercooling in a Lian-Li PC60 or PC61
Surely you end up shaking it and all sorts to get the water out of the radiator and blocks?
I was just wondering whetehr you guys had taken into account draining the system as its one of the things i end up thinking about for a while before hand (especially when i made my own reservoir and water blocks).
Er, no, just tilt it in whichever direction to allow those items to empty after the initial body of water has gone... no need to shake. When suspended in water, air will always rise. Just orient it so that it can. Water will always fall... orient it so that it can. S'y mavity was invented... :D
Personally, I don't use the pump at all for either filling and bleeding or emptying... always do it all with power off and just rotate the case thru whatever angles are necessary to get all bubbles to res, then top up. Only takes me 10 mins to fully fill n' bleed a rig.
