I saw that on your build blog beforeMust admit that it has been clear in my mind since lol
I got a backplate arriving tomorrowWell it should... None on OCuk so had to get from somewhere that sounds like "pan"...
Are those fans blowing out?
Just need a few ideas how to mount mine xD
Also do you know which ones are the in and outs? xD
Don't check your fans mate... I just checked here and they are the wrong way roundDOH!
Just turning them now lol
O good as for me to change mine requires a full system drain
At least you caught yours early and are easy enough to get to.
whay a full drain?
Just look at how mine is set up lol.
Id need to remove the rad from the front to get behind them as no screwdriver can get in behind it easily.
well, if your careful and have a friend to help, i'm sure it could be done![]()
Had a reply from EK. There should have been a steel and rubber plate in the box...Grrrrrrrr
