WC virgin needs some advice...
I have the fittings to do either way. What I was wondering is would there be more airflow if they were at the top of the case with the rad bolted to the fans?
Or would there be sufficient airflow with them pulling air through the rad?
Yeah, it'll be fine either way.
IMO, xfire connectors look good as they are :D
Well the res has arrived. However, still no sign of the mounting plate for the CPU block :(
It is much nicer than the 250 which was originally ordered. Thought it's only 10cm smaller it does look mighty fine.
Hopefully DPD will arrive soon with the CPU block backplate and then I can crack on :)
Is this with OCUK? You should ring up DPD and just mash the # key so you can speak to a human. Perhaps the driver is expecting some traffic.
My DPD guy arrived an hour early the other day so one driver has to have a bad day :p
Please ignore the screwdrivers poking out the back of the board with the CPU block on :)
This is the loop though in it's finality :)
