Which PSU are you using? I have the 450W modular Gold in my SG05 Titan rig and I would SO VERY STRONGLY recommend you make custom-length cables.
The PCI-E power cable has an annoying loop taking the 6+2 pin into the second 6 pin. I have my 2 2.5" drives in an Akasa dual bay jobby stuck underneath my PSU so I literally need 4 inches of SATA power cable with the connectors no more than 3mm apart, otherwise you end up with excess cable and loops everywhere.
Also be careful with how much paint you put on the inside of the case. My SG05 was originally the 300W model, so the insides and lid are bare metal. By the time I'd primed and painted black nothing really fits any more, and I've only used thin layers.
Wow looks fantastic!
Wish I had the balls to spray paint components![]()
Looking very sexy tbyeah, hope it all works in the end!
The SG05-450 and Lite versions should be all black internally. The Lite comes in white too and should be painted inside.
This may seem simple to some but yeah it's confusing me haha
The sprayed motherboard looks great. ( i would never do it personaly due to lack of giant mangrapes &money.
what im curious about though is would the layer of paint have any thermal implications to think about with north/south bridge capacitors ect
Thanks![]()
I think we have a winner![]()
