yes but being a bigger engine there is more torque, so even though the gears are longer, the torque to the wheels is about the same. So you dont lose any flexibility.
Which VTi did you have Dolph?
Try taking equivilent figure petrol and diesel cars on a fast road or track session and see how they compare, the results are pretty clear.
You do lose flexibility, because having a shorter rev range gives you a shorter powerband by definition (one of the key features of the VTEC engine is that it produces a pretty flat torque band over a huge area, over 6000rpm+ in the Type R).
Gearing can't counter the short powerband, in fact, long gearing makes the problem worse, because the gap between each ratio tends to be greater, which dramatically reduces gear choice options and flexibility in a fast road/track situation.
I love the mid range surge of my Audi, but I miss the huge powerband of my old VTI.
thats not the same thing.i didnt say a shorter power band though i said a lower rev limitthats not the same thing.
if they lowered the rev limit a little on a diesel turbo it would to.
I had an MB6 for four and a bit years
how do people rate the new integras?
Yes, but it will still have a short powerband in comparison. A powerband is the longest rpm range that has the highest torque. So if you can produce a flat torque curve from 2000-8000rpm, you have a much bigger powerband than producing more torque from 2000-4500rpm. Gearing does not enter into this, it's purely an engine thing. The gearing dictates how often you are likely to be in the powerband, not the size of it.
. Only 200bhp though...and not very tunable?![]()
i should explain better, and lets forget diesels as i find it unlikely they would ever have put one in it![]()
if you think of the power band as a percentage of the difference between the minimum and maximum available revs at which the engine is making usable torque, then your assuming no other engine can acheive such a percentage without vtec, which isnt true.
I love the looks of the DC5 and they seem quite rare?
There's a blue one I see around and it looks awesome. Only 200bhp though...and not very tunable?![]()
That's quite wide of the mark, they are 220 bhp and are quite tunable, although it's a costly exercise.
DC5 is import only, rather than having a UKDM variant like the DC2.
