- 14 Nov 2002
- Under the Hill
I have been having look on pistonheads and these seem amazing value for the performance. I am planning on a new car in January after I get my wedding out of the way and havve been toying with a few ideas.
My work commute is 10 miles on the motorway and I have a Rover 218 which is running well and reliable enough for those trips. My other half has an 04 plate corolla which is reliable and would be the motorway work horse for trips away etc. That got me thinking that maybe a car I could tinker with and uprgrade/mod bit by bit might be right for me and it's high time I treated myself.
So, with regards to Westfields, quite afew seem to be fitted with bike engines, but I really want to know what the ones fitted with the 1.7 zetecs are like if anyone has experienced them. Are there any engines that are just nice for me to get used to rear wheel drive with as an initial one to start out with?
Also, how do you evaluate overall value of the vehicle considering there are so many individually specced components used?
Thanks for any advice. Also,am I right in thinking that priced dip between december and february/march like a lot of convertables?
not really very commonly used. the 2.0 is bad enough let alone the 1.6!
