As I said my post was to point out the fundamental problem with Nashers crane dropping a battery scenario, and how basically that technology already exists. Yes i completely get how it would have to function differently for cars, but the point was this sort of thing already exists and is used daily all over the world.
Now going back to the actual dynamics of specific cars, I suspect will will see the following, if batteries do end up going the replaceable way.
There will be a decent amount that will be built into the cars as static "base load", lets say some 60kwh in a mid range size car. what they could also easily do is make some provision for shared space that can be used as storage or have one of a few standardised batteries fitted, doing this safely isn't a challenge. So as we now have AAA,AA,C,D etc batteries we may end up with car manufacturers and battery manufacturers coming up with 3-5 designs for standard swappable batteries. The car manufcaturers then integrate these into their designs.
This gives the base car the ability to do most peoples short trip frequently, but offer expanded range when wanted.
The model then for the extra batteries could be quite simple based on usage, frequent long distance travellers would be best to sign up to say "esso never run out scheme" where you can for a fixed monthly plus small per transaction fee drop into one of their service stations and swap out depleted batteries for charged ones. You would never own these, but just lease them.
Very infrequent long distance, but say for an annual holiday would just hire some for the same duration, again same model but with a one off payment for say two weeks and a similar transactional fee per swap.
Some people may prefer to own their own and charge them themselves.
What I am getting at is you don't have to have one thing or another, its completely feasible to have some integrated and some swapable in the same platform. It actually makes a load of the issues with both more acceptable. Like I said range for most people is only low normally, but maybe high occasionally.
To be honest I see the charging vs replaceable as like VHS vs betamax, one will start to dominate and will by default win, all bets are off as there are advantages and disadvantages to both.
But do I see massive batteries being hoisted into and out of cars, no. Can i see smaller modular batteries being part/all of the chargeable resource, absolutely. Just because you can remove them, doesn't mean you have to, you can have a charge controller and also make them removable.
