- 21 Jul 2005
- Officially least sunny location -Ronskistats
Russia played the long game and piled Gold then BTC. US is fubar if its not careful.
Isn't there break even if fracking $80 a barrel or more?The government shouldn't have been so hasty to ditch fracking it seems.
yea probably for at least 1 full year maybe even 2 it's not just GPU's, car manufactures have shortages of chips they need to manufacture cars too.the global supply chain is nakered to put it bluntly
the whole semi conductor industry is way behind.
intels investing 200bn in new fabs so they don't have to rely on TSM and samsung so much
Think wind especially onshore is cheaper than that.
I would hardly call 66 million people a small nation. By land mass it isnt huge but we have one of the biggest populations in Europe.. [..]
In light of the fuel hikes just hit, this is very serious and we cant depend on other nations even if it will take years to implement some more resources.
The context is wind power. Wind power stations aren't mounted on people.
Also, I didn't say that the UK is a small nation. I said it wasn't a huge nation. But now I'm saying that the UK is a small nation. 78th in the world. Not tiny, but definitely small.
The solution isn't "slightly complicated", as you put it. The solution is non-existent. There is no possible way for the UK to have a functioning independent electricity supply based on "renewables". It can't be done with any technology that exists or even any technology that might exist in the near future.
in Europe.. we are actually larger than France with access to lots of wind and tidal resources being an island nation.
Having less land mass and high population concentrations surely mean you have less of a problem moving energy than the larger countries?
I also mentioned tidal.
[..] The core problem is lack of control. The only control possible over wind power generation is turning some of it off. So you can turn generation down if it would be too much but you can't turn it up when it's too little. The UK is already teetering on the very edge with the current amount of "renewables" on the grid and the unreliability and instability is already a major part of the problem. It's getting worse by the day because the remaining reliable generation is being neglected (and thus becoming increasingly likely to fail), spun up and down to try to maintain the system with too little reliable generation (which is much less efficient and thus much more expensive), kept going past the time it should have been replaced (which increases maintainence and repair costs) or simply shut down entirely. At this rate it won't be long before the UK is wholly dependent on France (which has plenty of reliable and controllable electricity generation, so it doesn't have the same problem and can create a surplus to sell to the UK at a high price) and would collapse in hours without constant support from France.
[..] this is very serious and we cant depend on other nations even if it will take years to implement some more resources.
But this all started with the comment that fraking is an answer.
Nuclear is the answer.
Nuclear fusion is whats needed as the holy grail in a limitless supply of clean energy but unfortunately it always seems to be 30 years away.Nuclear is the answer.
Yeah. Can’t wait for them to crack this one. Will solve a lot of problems. We will have lots of cheap electricity and can start transitioning into heat pump technology in our homes, hell even AC’s.Nuclear fusion is whats needed as the holy grail in a limitless supply of clean energy but unfortunately it always seems to be 30 years away.
Yes, both wind and to a lesser extend pv are unpredictable, so storage when there is a surplus has to be part of the solution.
Hydro storage dams would add a fair bit of cost,
but since onshore wind has cheapest cost per mWh it seems worth investing in as it doesn't require importing fuel [..]
As for not being politically feasible, that is a problem. It seems that NIMBY's object to onshore wind, storage hydro so that they can drive their 4x4 in the countryside they are used to. [..]
[..] The only even theoretically possible solution at the moment is massive overcapacity in wind and solar on a unified transnational electrical grid which is at least continent sized. Which isn't politically feasible and which isn't affordable either. [..]
