For pure performance, the AOI cooler is the choice although they will be more noisy compared to the 'tower' air coolers, or normal heatsink as you call it. In terms of looks, AOI coolers are much neater with most of the pumps having cool lighting effects too. The tower air coolers are very ugly in my opinion.
Well the new kid on the block that came out top on the review of coolers with the 5950X I posted a page or two back is this: https://www.overclockers.co.uk/phan...water-cooler-d-rgb-black-360mm-hs-01e-pt.htmlThank you. What is the best coller under £200?
Anu suggestion?
This is what I have and it allows me to push my chip to it's limits for performance will maintaining temps I'm comfortable with. It's a classy piece of kit with a stunning infinity mirror pump cap. You will hear the fan's though if your CPU is working particularly hard. This doesn't bother me personally but it could be a big deal for others.
My experience with the 5800x is that it's very sensitive to improved cooling in terms of translating it into additional performance. Through default, not design, I had the Wraith Stealth followed by the Wraith Prism air coolers fitted, before installing the Phanteks 360 AIO. With each of these upgrades my performance scores in benchmarks increased (I started with less than 14000 R23 Cinebench multi-core scores and now get 15600). I even saw a further increase when I then upgraded to a larger case with improved airflow (not that my previous case was particularly bad or anything - it was a Full Tower as well). The bottom line is, for the Ryzen 5000 series, it does appear that there are real performance gains to be realised by having the best possible cooling set up.
I get it. The pull to have the best is incredibly strong but for some perspective, the difference in performance between the various top end cooling solutions is really only going to be seen in benchmarks; they won't really translate into "real world" performance. Selling and rebuying for such gains may not be viewed as very sensible and/or rational but I get that this hobby does often allow for those traits to be trumped! I know I have sold parts and bought others for minimal gains just to have the better part. For example I sold an i5-6600K after a month and bought the i7-6700K as it was bothering me that I didn't have the 'better' chip even though I only used my PC for gaming.Dear me, this thread keeps pulling me in different directions. Now I feel the need to sell the Dark Rock Slim and get one of those !
When I started monitoring the temps I was shocked to see the same - despite my AIO coolant temps showing as being in the low 30s. I went through numerous re-sits and changes of thermal paste types before reading up that this was normal behaviour. The chip boosts up to temp very quickly by pushing the voltage up for a short period - faster than it can be dissapated by the IHS, let alone the cooler. Under more sustained loads the temps hover around 70c.To add some context, the 120mm AIO i had the 5800X was putting out temps in the high 80's, up 90c in Cinebench.
Its an old cooler so i though it was time to upgrade, the Arctic Freezer II comes very highly recommended, so i got one expecting to shave at least 20c off my temps, nope... its now in the low 80's, so about 5 to 7c lower, that's when i learned the 5800X just likes to run at those sort of temps and there isn't much you can do about it from a cooling point of view.
It is what it is, its apparently completely normal and expected so i'm ok with it, just wish i would have known i would have settled for a cheaper cooler.
That seems very hot to me and I'm not sure if I need to be getting worried about a bad mount
Spotted this, not a bad price - https://www.overclockers.co.uk/b-grade-be-quiet-dark-rock-pro-4-cpu-cooler-bg-116-bq.html
Dark rock pro 4 handled my 5800X easily. Takes the 5800X3D even easier. You could try limit your PPT, TDC, EDC for a less than 5% loss.Reviving this as I've been thinking too long of replacing my Dark Rock Slim. I've noticed the performance in my PC being a bit funny at times and could probably do with improving CPU temps.
Are these bad for a 5800X and should I get a better cooler? Max temp in red suggests (to me) yes to both.
What kind of temps were you getting on Dark Rock Pro 4? Which paste did you use?Dark rock pro 4 handled my 5800X easily. Takes the 5800X3D even easier. You could try limit your PPT, TDC, EDC for a less than 5% loss.
I done it my old 5800X swapped into a mates PC who didn't want to change from the AMD wraith cooler (don't ask) and temps seem stable enough. I tell him often to upgrade his cooling though.
I normally use Noctua NT-H2, to be honest I never expected my 5800x to go past low to mid 70s while gaming. I'll pull up some benchmarks if I still have them.What kind of temps were you getting on Dark Rock Pro 4? Which paste did you use?
