Which size monitor do people use?
2 Dec 2004
Under The Desk, Wales
Guys, i am in the process of trying to put together a Gaming PC for myself.
I am going the SFF route but need advice also on a monitor. I have a 20 TFT but was wondering what size do people 'Generally' use these days with their PCs. My TFT is around 10 year old now and i was wondering if i should get a bigger screen.
I am thinking of mounting it on the wall in my kitchen. Maybe i could get one that i can use as a TV too? Not sure though as i dont watch much, if any TV. Its all PC for me, via my laptop.
So, what size Monitor?
What fixing for a wall mounting?
Cheers
22" but will get a 24" very soon. Think I'm in the minority but I don't want anything bigger than that for something I sit so close to.
I use 27inchx3 IMO thats the sweet spot for 1080p I wouldnt go bigger for a desktop monitor at 16.9 unless it was one of those ultra wide.
I think the size of the monitor that people use is relative to how far away do they sit away from the screen.
If you are looking at mounting it onto the wall, then surely you should probably be looking at 27" at least?
For 1920x1080 res I wouldn't really recommend going beyond 24"; 25"~27"+ should really be already on 2560x1440 in order to look good.
I suppose you could have a look at the 21:9 monitors as well if you play lots of firm contents at that aspect ratio:
https://www.overclockers.co.uk/productlist.php?catid=2907&groupid=17&sortby=priceAsc
so that it wouldn't look smaller with the 21:9 content being fit into a 16:9 display looking smaller and leaving two black bars at top and bottom.
I will be about 3ft away from the monitor but, i am thinking of getting a wall mount so i can bring it closer at times
currently an LG 34" Ultra Wide but its going back and im going to wait for some of the new 27" ips 1440p G-Sync monitors to arrive and decide which to buy from then on.
24" NEC MultiSync 24WMGX3 @ 1920x1200P, had it around 6 years.
I'm on my 3rd VA type panel in the last 10 years having used P-MVA, S-PVA, and currently my A-MVA screen above.
I tried a TN panel for a few days and did not like it at all, crap viewing angles and washed out colours compared to my VA panels I've been used to, so I had to DSR it.
Not sure what I'll do next, I quite like the idea of the BENQ 32" 1440P A-MVA or the AOC version coming out, as it's the same pixel density as a 1200P screen. Otherwise I'll have to go 27" 1440P IPS, I'm holding off for now.
Using a 42" HDTV (1920x1080) from a 1m distance (~3.2ft).
In any case, what bothers me is this:
You're building a "Gaming PC" ... in the kitchen?? Those things don't really add up. Also, first you were talking about SFF, but then you said "it's all PC for me, via my laptop". Or was that sentence related to the TV watching? All in all, I'm a little confused as to what you're trying to build here.
Are you looking to play some casual puzzle gaming while eating a breakfast, or are you building it as your main rig, with the main usage scenario being gaming, and for some unknown reason you want to place it in the kitchen?
If the former, then keep your 20" monitor, you don't need anything special. Actually, a tablet would be a much better option, instead of a gaming PC.
If the latter, then some generic 24"-27" IPS or VA screen should be fine. Well, depending on your own eye sight, of course. From 3ft, 27" might be a better option.
Only place i can have the PC is on the kitchen table that is why i currently has a laptop which is naff at Gaming.
A SFF is the best option as i can keep it small.
Kitchen table is against wall so i can mount a 24" Monitor on the wall with an arm so i can bring it closer if need be and when the kitchen table is moved away from the wall.
