- 11 Jan 2006
- Frimley, Surrey
Un-ruddy-believeable............of course the green car has the right of way!
Ignore the existence of orange car and pretend it's just the yellow and green car. Doesn't the yellow car have right of way? Yes, you give way to the right at a roundabout but the green car isn't to the right, it's simply on the opposite junction.
Or do both cars have the right to go? Because if they both went at the same time and at a reasonable speed, they wouldn't actually hit each other, since the distance the yellow car is travelling is shorter than the green car.
I've lost count of the number of times I've been at a mini-roundabout where there's been some kind of stalemate because no-one knows what to do, myself included.
Oh great Lords of motoring etiquette, enlighten me.
The car already on the roundabout has right of way, end of story*
*Of course its not end of story otherwise there wouldn't be such a huge debate. It is almost impossible for two cars to arrive at exactly, to the nearest millisecond, at the same time. One will have arrived just before the other. What usually happens is neither can work out who was first so both dither for a bit before somebody then goes.
Yes, if you are the yellow car, you wait for the green car to go. If you arrive at the same time and see the green car, you let it enter the roundabout first then see which exists it takes, if it takes your exit (where you are from) then you go, if it takes the orange at exist, you follow it after its past you.
That's the way it works, not rocket science is it?
If I was the yellow car, I'd give the green car right of way.
However if it's a mini roundabout (which is what the picture suggests) then Clarkey, your solution would probably result in a crash.
If the green car and you approach the roundabout at the same time I can't see why I would have to wait for that car to do it's business, if the green car was already on the roundabout then yes, I'd wait.
Because it has the right of way, being on your right.
Logical?
What's shocking? Are you seriously telling me that if you were the yellow car and green car approached that roundabout at the same time that you would sit there and wait? Now I wouldn't deliberately do something to cause an accident but if the green paused I'd be on the roundabout in a shot.
I guess the crucial point I missed out on is how big the roundabout is... eg:How? The other car is opposite. If you both arrive at the same time then you could continue at speed and clear the roundabout before they have even started turning, they are going to be going much slower in order to make the turn. No crashing or anything remotely close to crashing needs to be involved.
Honestly can't see the point in that roundabout, what is wrong with a T junction? It looks so tight that you'd have no choice but to cut over it when turning right.
Means people braking and accelerating for no valid reason if you ask me. More noise pollution for the residents, longer journey times, consuming more fossil fuels, emitting more evil co2.
