Caporegime
- 18 Sep 2009
- Dormanstown.
Meh.
Meh.
Exactly. His 70 FPS is because of the GTX 680 SLI, not his CPU.
I think you're forgetting where he used the 680's with the FX8320...
I really can't be fussed with this, all you'll do is move the goal posts, ignore something, make another mistake, misread another thing and so on and so forth.
I mean, you've done most of that this thread already.
I didn't realise i would have to spoon feed humbug but here goes.
The test you are running is hard on GPU's
A single GPU such as a 680 or 7970 will only average high 40's. maybe low 50's on a highly overclocked card.
Now you wanted to test CPU Physx.
I did the test using 2 cards which are capable of 90+ frames per second.
The result when using the CPU to do the Physx, a miserable 30 FPS with the FX 8320.
For comparison i used an Intel 3820 running at the same clock speed as the FX 8320 4.6GHz.
Actually 4625 because you have to use the 125 strap as they have only partially unlocked multis.
That when doing the Physx was able to sustain a much higher FPS as i showed over 70.
Now had i used one card the result would have been in the 40's.
The GPU would have been the throttle not the CPU.
Understand now ?
One GPU and you will not see the max Physx capability of an Intel CPU using your test settings.
Did a metro run on my FX 8320. 4.6Ghz
680 SLI
I can turn off Phsyx on the GPU and do another run.
Just went into the NV control panel and set Physx to CPU.
Performance as expected is terrible running Physx on the CPU.
Minimum frame rates well under 10 and averages in the 30's why would you want that.
FX8320 4.6Ghz Physx running on CPU
It also runs off the CPU if you don't have an Nvidia GPU.
Actually it runs quite well on the Intel chips.
I had no trouble averaging in the 70's on the test with a 3820
CPU Physics
