Haha OK pal.
No you wouldn't.
Why do you say that? I buzz my hair down to a No.1 because if I don't I get horrible eczema on my scalp. I wouldn't change back to letting it grow long either, I'm used to it and genuinely prefer it.
Haha OK pal.
No you wouldn't.
Same here, it's been a bugger keeping control of the eczema/psoriasis while I let it grow a bit.
If this is something you haven't tried, give it a go.
https://www.amazon.co.uk/gp/product/B004H6YKPE/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
No idea why the images are what they are, but that's the correct listing (bought some in march).
Or this.
https://www.amazon.co.uk/Head-Shoul...words=selenium+shampoo&qid=1623774005&sr=8-25
Selenium Shampoo is expensive but having such short hair we only need a small amount each time. It really does work for me though (there are other sorts available, I just know these ones work), alongside the short hair, nothing else helps!
General anti dandruff shampoos including T-Gel, Charcoal variants and generic Anti-Dandruff options do nothing to help.
I use a remington quick cut with no guard on my head. I had to accept I was looking a bit thin on top and lockdown was the opportunity to change.
These days if I go a week without shaving it I feel I look a mess.
