- 13 Jan 2004
- Leicestershire
Shaven haven here. I use Gillette disposables and shaving foam.
Just clippers without any grades and on low setting for me.
What sort of cream do you guys use. I'm fining my head it a bit dry
That's why you can't beat the "Back, Sack & Crack" approach!
I do. Once every couple of weeks I shave using proper Mach3 razors, and then in between maintenance with this.
Quite the thread revival here!
I have a Remington HC4250 cordless unit that fits in the palm of my hand. I use that with no guard but it's not particularly close. Searched the forums to see if I can pick up any decent tips.
Since reading this thread I decided to purchase a Headblade Moto and some HeadSlick. Didn't think I'd go for a razor but I don't like my current routine of shaving once every two weeks and it's a chew on compared to shaving in the shower.
Might end up just using my Gillette razor and doing head n face at the same time - if that's a socially acceptable and perfectly normal way of doing things?
I actually quite like shaving it all off now, if I magically got a cure and got a full thick maine of hair to grow I'd still keep it all shaven off.
And for my balls.....
This is the one you want https://uk.remington-europe.com/products/ultimate-series-rx5-head-shaver
Basically as close as a razor, run it over my head in the shower every other day. Tried the head blade and normal BIC style razors, the head blade was a bit crap normal style razors were generally just as good or better but the ease and convenience of the electric is the way forward.
Bulldog products, shave face/head most days. Shave, shower and then moisturiser.
This user probably didn't expect to be called out 5 and a half years later but boomHaha OK pal.
No you wouldn't.
With all the imitation versions of the Remington shaver on Amazon it was too much of a minefield which is why I opted for the razor thing. How long have you had the Remington unit? Have you had to switch blades yet? If so, expensive?
