Even after giving it an good stir, it's pretty oily. Especially the Pip & Nut products - terrible. They're just like putting wet slop with the odd peanut onto your toast.
I always make peanut butter myself. Well technically the supermarket does. Nothing beats fresh made peanut butter. Over here you get peanutbutter in the aisle with the coffee etc. Instead of grinding coffee there is a machine that grinds up fresh roasted peanuts for you, or almonds.
With no preservative it wont last too long out of a fridge but worth it.
Where do you live? That sounds great!
For the DIY - grind it at home option -
Will grinding nuts rapidly kill food processor blades ?(never replaced them yet, but would not want to sacrifice them),
for almonds would skins still on or off=white/bleached be the better choice ?
Serves one
Toast two slices of bread, then butter them. Turn butter side down and spread one naked side generously with peanut butter and the other with honey. Fry three rashers of bacon until crisp, then lie them on top of the peanut butter. Cut half a banana into slices on the diagonal, and lay on top of the bacon. Top with the honeyed slice of bread, buttered side facing outwards. Slide the sandwich into the pan in which you fried the bacon and cook gently until golden brown on both sides
I use Pip & Nut nut butters, far too nice so they never last long.
Tempted to go from Sunpat to Meridian. Do you guys buy the no-salt version?
I'm sneaking it onto the Ocado basket. I suspect the girlfriend will be furious
