gpu inserted correctly by a Pro computer guy, and working for several months before needing a reseat to fix a no signal errorProbably to rule out the cause being that it was not initially inserted correctly by the user. If you have been inserting correctly then perhaps there is some environmental issue as a contributor.
Maybe the cat or dog is playing rough with your pc when you are not there? I've never had to reseat my gpu either. Advice about reseating it is normally just one of them things people just like reinstalling the drivers etc.my PCs and my kids PCs
I'm not talking about reseating a gpu because it has fallen out of the socket! but to fix it when suddenly there is no video signal coming from the pc
I refuse to believe that I am the only one to know that reseating the gpu, can fix a no signal error
Maybe it was the 16 pin power cable that was the problem, didn't the earlier versions have a habit of working loose just by the flex of the cable.as long as I have had modern pcs, there have always been seemingly random times that the gpu needed reseating to fix a boot display problem, but why,?
It's not like they are taken out to allow some dust to get in the slot? they are pretty much left there alone, static, working, then boom- reseat me plz!
so, I just don't understand!
yes, I crapped myself a little with a gpu debug white light on yesterday, cba with a broken 4090, I had to wait until my son got back from his twilight shift job to reseat it for me, it took x3 reseats before the white light went off , and I got the sweet green light again
any idea anyone?
EDIT:just to be clear, i'm talking about fixing a sudden no video signal error, or a vga problem debug led
Where can I do a course to learn how to be a pro inserter?gpu inserted correctly by a Pro computer guy, and working for several months before needing a reseat to fix a no signal error
run your own business, employing only yourself for 20 years building, fixing and troubleshooting PCs, memorise all the windows cmds, and have a side hustle, building, maintaining servers for some big business clients, and also survey sites for serversNever had to do it and ... Ah
So reseating a gpu is something you do try/advise to try. has it ever worked, for you to be advising that?Only ever been required during build to correct an error or after moving the tower, and even then it's basically never.
It's suggested as a fix for no display output after checking and reseating all cables, as it's an easy test and one doesn't know the situation of the users machine, so it's good to eliminate before wasting time doing other, more difficult stuff.
I have often had no signal being caused by bad/incorrect cables. The one situation I can think of it working, is if your monitor doesn't have a scaler in it, or a limited one, and your gpu/system has got stuck it outputting a different resolution. Then reseating the gpu resets it, and then it gets displayed correctly again.
Id suggest going forward, trying other steps before reseating the gpu, to eliminate other options, so that in future you might have a quicker fix.
Regardless of anyone's experiences, you *shouldn't* be having to do it with any regularity, especially if the tower isn't moving. No components should spontaneously be breaking/disconnecting "regularly" on a hardware or mechanical level.
Once built, I'd expect maybe one component every 2 to 3 years, if unlucky, not weekly or monthly.
