Ha i don't think this thread has gone as OP expected.
Still use DVI here.
Really? I asked why it's still in use. I have my answer.
.Your question was loaded in the opposite direction to the outcome though, therefore the answer is not what you thought/expected.
So yes, really.
But the answer is wrong, this thread makes it sound like DVI is in high demand when in reality Nvidia could drop DVI tomorrow and ship the cards with a 2p HDMI-DVI adapter and nobody would be hurt by it apart from the handful of people using VGA only monitors as second screens.
I would be annoyed by any card that didn't have DVI and it would prompt me to look for alternatives.
I am using dvi also and imo it would be better to scrap hdmi and dp from a 980 ti making the card single slot for all us dvi users
It would be cheaper also i imagine.
What's wrong with it having DVI?
If you look at the current Nvidia line up, they all have DVI connectors on the back of the cards:
Now I'm by no means an expert in cooling, but would binning off that connector and the associated electronics create more room for airflow which would increase the performance of the reference coolers on Nvidia cards?
Who still uses DVI? It's dated now isn't it? Most people are on display port, and if DVI is a must, then there are adapters available.
Thoughts?
It's not even like adaptors a cheap or anything, to go from dp to dvi 1440/1080@120+ you're looking at a £70 adaptor.
