I use DVI and wouldn't be interested in using any kind of adapter. Once you start adding adapters you run a greater risk of signal degradation to the screen which is not something I would want to suffer as I use my PC for photography.
That's one that's capable of VGA output, a regular DP-DVI adapter is much much cheaper and included with some cards, a HDMI-DVI adaptor is pennies and included with even more cards.
Also you're back to horrible badly secured easily breakable HDMI rather than nice sturdy well-affixed DVI![]()
I'm curious to know what the DVI holdouts think should be the cutoff for dropping the port... 2017? 2020??
They appear to have done that with Fiji going by the render that is floating about.
In the interests of full disclosure given I've been pro-DVI in this thread so far I should probably mention that I don't actually use it on any of my own machines. However, whenever advising someone not very computer-savvy about connecting stuff up then if possible I'll advise it as it'll be easy & problem-free.
Is that DVI going to be a pain for watercooling. If the DVI wasn't there, and in theory if there was no cooler (or a very thin waterblock) it could plausibly only take up one Slot, which would be nice imo.
I guess it is only there to be converted to VGA, but I would have thought if you are buying a card that powerful, you will more than likely have a monitor that has DP or DVI.
