Some settings can't go higher, even if you select the highest preset. Texture streaming remains on Ultra.
I know what I am doing everything is manually set to highest it goes after choosing "Mien Leben" so it now shows as custom.
I can set Texture Streaming and Shadows to Uber, the rest mostly Ultra with one or two Highs.
VEGA 56 vs GTX 1080 Lol No competition...
lool
Hmmm I watched the video and took pictures of settings and copied same settings on 1080p I get 120-130fps on 388.10 hotfix driver, man SMAA was horrible gave me a bad headache after played for a min. Installed new 388.13 driver and restarted PC then ran again, wow very impressed to see massive boost 170-200fps. I never played games at lower settings, always played with all settings maxed out at 1080p with TSSAA 8TX I get 160-190 fps.
Very impressed with new driver.![]()
250FPS Shanks.Very niceIts not quite 200FPS Plus!! tho
AMDMatts Vid
So the 388.13 driver makes a difference?
Use 17.10.3 benny.
RTSS 7.0.0 Beta 30 worked for me regardless of driver.
Hmm.
Have another watch, Vega is only ever ahead at the cut scene at the start. In all gameplay the 1080 is comfortably ahead.Bit of a mixed bag sometimes VEGA wining, other times the 1080 is winning.. All in All a good showing
I would like to see HBCC tested also, I gained quite a big fps just by enabling HBCC
Exactly, this is what I have been saying from the start, as per PCGH and ComputerBase testing, AT MAX SETTINGS, Vega wins in non taxing scenes "like cutscenes", in taxing scenes "like outdoor scenes" NVIDIA wins, sometimes by a massive margin. You can see that in the video which has a nice mix of outdoor and indoor scenes.Have another watch, Vega is only ever ahead at the cut scene at the start. In all gameplay the 1080 is comfortably ahead.
ComputerBase tested that as well. Mild gains at best:I would like to see HBCC tested also, I gained quite a big fps just by enabling HBCC
https://www.computerbase.de/2017-10...diagramm-radeon-rx-vega-64-mit-hbcc-3840-2160
4K and max settings?Wouldn't call this mild gain
From 78FPS off to 100fps on
