Just a bit of an update, car is back on the road and has been running as my daily for the last couple of weeks.
Things I've done since getting it back:
- Oil and filter change
At the moment it's running on cheap oil to move some of the rubbish that's accumulated from the short runs it's had. Will be changed for Miller's at the end of the month.
- Spark plugs
Running on Kia plugs... £4 a set and they're the Rover recommended OEM ones too
- Water leak
When I had the car last time, it was slowly losing coolant but was never enough to be an issue - about 100ml a week or thereabouts.
These were the cause (from a member of MG-Rover.org):
In the picture, note the blanks which aren't sealing properly. The diesel variant of the Rover 600 uses 2 temperature sensors in the radiator, and instead of making 2 different radiators, one with the sensors for the diesel and one without for the Ti, as Rover originally did, 3rd party manfacturers fit blanks to the ones sold for the Ti.
These were leaking badly, so I got the sensors from a 600 diesel radiator and fitted them, leaving them disconnected.
- Car wanders, and doesn't handle well on fast corners.
Yes it's a boat, but steps can be taken to rectify as when new they handled pretty well for a barge.
I give you, front anti-roll bar links!
Swapped these, the originals were well and truly knackered. Improved things to no end!
- Front tyres worn, and cracked due to age.
Swapped out the knackered Pirelli P6000s for some pretty good Nexen CP641s, seem to grip well and keep the power down.
- OEM exhaust corroded, and not particularly attractive.
Picked up a full Mongoose catback system from someone breaking their 600 for the princely sum of £50. Bargain! Set about fitting it:
Sorted.
- Gash Lockwood dials
These were fitted by the previous owner, byebye you go!
...Better
The only other issue I had (and I got £50 off for this...) was that it would idle horribly, constantly hunting. I noticed the TPS wiring was loose... the metal retaining pin was missing! 50p later all sorted.
Got to say, for what is supposedly a naff car by a company that doesn't know how to make cars they've done pretty well...
All going well, for now!
