Its the same as a 75W-90 gearbox oil
I have been reliably informed that MTF94 is a very similar spec to 10/40 semi, so much so that Rover used to recommend it before moving across to the MTF.
Fair enough, I only had the 10/40 in for a few K and it came on looking like crap!
After much searching I got the 94, although it was a pain in the ***
Who were you on MG-Rover.org again? Memory fails me![]()
Mat, you mean you were able to undo the gearbox filler plug?
Even when I had the box off, I couldn't get mine undone.
I just fill through the speed drive instead!
Need to manup to be honest Andy. Real men can undo any stubborn bolts etc.![]()
Seems to be too common to be otherwise eh!
Could a sticky caliper account for 2-3mpg drop?![]()
Stuck caliper, yay!
On Monday I'll be stripping it down and rebuilding, this should be fun. Wish me luck!![]()
Recon caliper and a set of new pads would be the best option....
Dave, you didn't used to own a charcoal 420 GSiT did you?
I remember the username from a few years back.
Any reason for this? Seems they come up fine when rebuilt![]()
