- 1 Jun 2014
What did Dell have to say about it?My order number is currently not showing as valid and not on my account whatttt
Glad to report no seeing that on mine. I run through the usual RGB + BW colours plus this #22222 one I made myself.I am only really noticing a line/impression line down the middle (like exactly the middle) of the screen and only on certain greys it looks like. This is new as could swear it was not something I noticed in the first few days as ran through my colour palette PNGs when I first got the screen to check uniformity etc.
I believe this is the sort of thing that is adjusted for during "pixel shift" and also panel refresh. I have not yet done a panel refresh though as it takes an hour.
Agreed on that front.
So far trying out 63 brightness which is 140 nits according to Vincent. Looks good on desktop, going to see if I can stick with that
Got my first pixel refresh pop up. Seems to basically come up when you are turning off the monitor and you just click to proceed and it turns off the monitor once it is done. Nice and easy.
Had a quick go on Counter Strike GO. Definitely a night and day difference in motion clarity and smoothness. Also did enjoy the ultrawide aspect ratio a lot for it.
@Nexus18 What are you using 8bit 175hz or 10bit 144hz? I tried both but can’t really see a difference in image quality
Phew!Looks like it must have been a website hiccup, as it’s showing now! Panic over, for now
How much was the order price on your second monitor?Well dell are giving me a 10% discount on the second order so can't complain too much, yet.....
@TNA
ATM 175hz 8 bit, mainly due to not noticing any banding and in the games where you can run higher than 144+ fps, the benefit of higher hz is somewhat noticeable. Yet to really notice flickering (outside of the flickering with dark grey backgrounds etc.) in usage with the higher hz.
I am going to try both out for a while and see how I get on. Had it on 10bit 144hz until a few hours ago.
Damn. They only offered me 7%, might have to try and push for 10%847
Still to get Quidco cash back and £100 from amex
No Amax either
Just 8% TCB which who knows if it will get paid.
so £662 now?847
so £747 now?
What do you say to support? Like you just ask for a discount because delayed and they just give it to you and even applying a discount to your already discounted order?Then amex £100, will bring it down to £663
