I really hate these fans.
Guy on Reddit replaced them with noctuas so it is possible
I use this two sided MF cloth for cleaning the panel, the yellow side is for glass etc and has yet to micro scratch the surface:
Every day!?! And people think I over do itI got a set of 5 of these from amazon btw!
Tend to give the screen a once over every day as it's a habit from the matte coated IPS where dust would settle overnight so just continuing that routine really.
Yeah I had that happen when I tried to rub something off that wasn't going to come off without a bit of water. Been a lot more careful since.I cleaned a small area of the screen with an apple polishing cloth and it got micro scratches on the screen afterwards.
They aren't visible when using the monitor but annoying that the coating is so fragile on it.
Some glass panels are a nightmare to clean but with the right cloth, it's easy. Most cloths all it had done was shift the fibers about the screen but never lift them. The good ones lift it completely and any subtle marks. Including water marks.I use this two sided MF cloth for cleaning the panel, the yellow side is for glass etc and has yet to micro scratch the surface:
1year Advance Exchange for £74.54
2year Advance Exchange for £148.88
Please be informed the Burn in Protection is part of Accidental Damage Cover which is available only at the time of purchasing the new machine hence it is not included in the new warranty.
It was this:Would you happen to know the name of that cloth? I could use a decent one.
