Thought I'd better update my own post to avoid any further disappointments!Least you ge to playFS2024 and Stalker 2 on Wednesday via GPU on the SX! That's what I plan on attempting!
Unfortunately it doesn't. The rates changed again during the past summer and you'll get just over 3 months instead.If I was to add 12 months of Core to my son's existing Ultimate, would it convert to 6 months Ultimate?
Yep. This is what I have at the moment, it was just to try out BLOPS6 Zombies, and now I'm hooked and 1 month doesn't seem long enough@rp2000 You can buy 1 month ultimate for £8.99 from cdkeys as well.
I meant when you converting your 24 months gold into ultimate at the same time you can buy 1 month ultimate at the price of £8.99 from cdkeys rather than getting it from store for £14.99 to make it bit more cheaper.Yep. This is what I have at the moment, it was just to try out BLOPS6 Zombies, and now I'm hooked and 1 month doesn't seem long enough. But it will work out expensive if I keep buying the 1 month codes.
rp2000
Interesting, I never realised you can use the ultimate cheap codes to upgrade your core/gold membership!I meant when you converting your 24 months gold into ultimate at the same time you can buy 1 month ultimate at the price of £8.99 from cdkeys rather than getting it from store for £14.99 to make it bit more cheaper.
rp2000
Yes, I've done it before, the only difference is that I was getting the core/gold via cdkeys and then buying the ultimate upgrade via the web as it was offered for £1 back then. This was a couple of years ago though!That's how the "hack" works.
Get codes for Core (used to be call Xbox Live), get it for 3 years. Then 1 month of Ultimate, and it converts the entire thing to Ultimate.
It used to be 1:1. Then it went to 3:2 (3 years to 2 years), now it is 2:1. So 3 years to 18 months.
Since you used to be able to get 12 months XBL for like £30, so it was silly cheap.
Now I think about it, it makes sense that the upgrade part also works with the ultimate 1 month codes via cdkeys, your xbox account already has the core subscription on it, it doesn't really care whether it is upgraded to ultimate via their webpage or via a cheap code, it applies the conversion ratio regardless.
rp2000
Mine runs out in two days. Has anyone added core to an already ultimate gamertag?
If I add 24 months core to my ultimate subscription will it convert to ultimate essentially saving me to buy the 1 month ultimate?
No, you'll only get just over 5 months added to ultimate for every 24 month core code you redeem on an already active ultimate subscription
You're better off letting the ultimate run out. Then buy 24 - 36 months of core, then convert to ultimate at a ratio of 2:1 i.e. 24 months core converts to 12 months ultimate
Jumping in on this thread, PC user only looking at the game pass.
So, buying a 2 years Core version from somewhere like CD keys, assuming they're about the cheapest, and then convert that to 12 months Ultimate.?
How is that conversing done.?
Thanks.
Has anyone done the India vpn method recently ie over last few days successfully? Looking at reddit/ hotukdeals they are cracking down on this/ vpn no longer works? Want to add this to a kids account but you cannot change region on them.. Might have to create a new adult account so can easily change region to redeem
Did you try the Indian route? Mines expired now and looking for the cheapest way to do it
