XenForo 2.3 bugs, problems, and new stuff thread!
Quoting posts, or even just linking via the post number automatically embeds the post. Looks terrible - please revert asap
Odd, on my android phone I just tried to click the like button and it proceeded to try and download the forum. It gave the impression it was trying to download the entire forum :eek:
Worked the second time I tried.
Huh.
The image browser when you load an image and click to zoom or swipe across a gallery sis much faster now.
Neat.
Seeing some scrolling glitches on IOS/Safari. If I flick a page up or down, sometimes the scrolling slows to a stop as normal, sometimes it just stops suddenly part way up the page. Also seems like it just stops scrolling sometimes when keeping my finger on the screen and I have to swipe again.
  • Passkey support (no more 2fa needed if you use these)
That is so cool. Never used a passkey before but clicked the button in my account area, Nordpass took over and created one. I logged out, went to login, clicked Use Passkey and boom! Straight back in. Very cool.
OCUK my first every passkey!! :cool:
Yay think a bug I had where it struggled to put the cursor after using an emoji has now gone.
The alignment button for me is skitzing out.
I get a 'show' link on the deleted post above, but the link doesn't work. I'm not sure if that's new or not, wouldn't have thought I would have the permissions to see the link.
:) Passkeys are the future. Are we have them now.
I use them whenever possible now, they just make life so much easier.
Can I ask a slightly off topic question - but now that a passkey is being used, is there a way to remove or disable the use of my old password (for security)?
Here's a bug, if you disable 2FA and use Passkeys, then this works fine on desktop, but if you the go to mobile via the phone web browser (also Firefox though not relevant) then you can add a passkey for that device and it saves fine and shows in the list of passkeys, but when you go to log in via mobile web browser it tries to use Google to find the passkey which obviously doesn't exist
Also once passkeys are enabled, you can't then go in and re-enable any other 2FA as the toggle switch doesn't do anything.
