dazza121 said:You did replace the plastic mounting bracket on your motherboard didnt you (heatsink should have come with a new 1) that pic looks remarkably like your still using the original bracket as the heatsink isnt making contact with the processor.
StevenG said:correct. i did everything i was supposed to do and i get higher temps that my stock which i now have back in
StevenG said:it was all as tight as i it would go without breaking my board. the black plastic bracket didnt move and the heatsink was very tight on the clips.
StevenG said:could someone please give me some temps with a opty 146 at 2.8 and an xp-120.
z0mbi3 said:Duff temp sensor!!!
Have you tried touching the heat sink while it's supposedly at 50 whatever degrees it is your seeing?
Obviosuly be careful when doing so. I very much doubt those are your real temps.
Input from others? I can't be the only one thinking this.
