My crossover is also at Heathrow customs with missing invoice.
Got mine from Red-Cap.
Hells Bells.
HDMI, no.
DP not directly, but if you use a displayport -> DVI dual link adapter it should work quite nicely. But yeah that's another £74.99.
Mine is now held - available upon receipt of payment. I paid £19.50 online earlier, hasn't updated yet so I think it'll be tomorrow now.
So thats a 2560x1440 IPS monitor with 120Hz refresh?
Sounds insane
And here I am stuck with lowly 60Hz Hazro...
I picked up a mini DisplayPort to HDMI adapter for £4 recently, I haven't checked but I imagine a dual link DVI cable wouldn't be much more if not a similar price. Why then are these adapters so expensive?
Who was the seller?
Did yours get held at customs or was the tax from somewhere else?
Sounds insane
Maybe there are licensing fees involved. I genuinely don't know, but it's extremely frustrating that I can't use one of these monitors for the same price that everyone else is paying.
Earth[Tera].bin;21641263 said:May find a FedEx import duty bill posted through your door a few weeks after delivery. I had that experience lately.
ha. why would anyone pay after receiving the monitor already?
It's more than that. I don't know exactly what is required but display port to dual link DVI is not pin compatible; the adaptors require power and are 'active'. They are manipulating the signal in some way and as such that is why they are expensive.
If your display port is a displayport++ you can get away with a passive adaptor but I have literally no idea how you can tell that.
ThanksI've never even heard of DisplayPort++ until now. Can't they just keep these things simple?!
EDIT: One of the reviews on this page states that the passive adapter does work with the Dell XPS 17 (L702x) which is the laptop I have. Interesting...
Unless you go a very good deal, it sounds like you purchased a passive mini-DP to HDMI adapter (like this one). In many circumstances this will work fine (they can be cheap as they rely on the graphics card outputting what is effectively a DVI/HDMI signal over the DP connection - so it is only a simple pin-swapping adapter that is needed).
In contrast, active mini-DP to single-link DVI or HDMI adapters (which unlike a passive adapter actually convert a DP video signal into DVI) are much more expensive - here is one for £24.
In addition, for a dual-link DVI connection you need an active (not passive) adapter to support the high bandwidth signal and to achieve the much higher dual-link DVI bandwidth the adapter needs to be even more complicated than a single-link DVI one, thus adding to the cost.
The price of the DP to dual-link DVI active adapters is rather high, but DP to single link DVI/HDMI active adapters were a similar price a few years ago - since there wasn't much demand. However, recently the demand for these single-link adapters has grown massively (as many more people have graphics cards with DP output and eyefinity can be achieved relatively cheaply with 1080p/1200p 60Hz monitors), therefore many more companies now sell them and prices have tumbled. Hopefully, something similar will happen to the DP to Dual-link DVI adapters as high resolution (and 120Hz) monitors and graphics cards with a DP output seem to becoming increasingly common.
That means you can use a single-link DVI or HDMI monitor with that adapter/laptop, however - to run a high resolution monitor (like one of these 2560x1440@60Hz ones) you will need a dual-link DVI connection. So in that case one of the £75 active DP to dual-link DVI adapters would be required.
