I take it they are 60hz out the box, how do you force them to be 100hz or 120hz?
Seiously tho, someone needs to import these and sell over here, they would make a killing Hazro I wouldnt touch.. Even with TAX and Import still works out a fair bit cheaper then a Hazro.
all of them will 60hz yes, depending on the pcb board some of them will do 75hz and even 100hz. on another site they where talking to manufactors about getting more with 100hz or even higher boards.
And the manufactors all seem up for it. Seriously maybe one of the buyers on this site should contact them about a nice OCUK branded one
And you think the prices for them are cheap on ebay ,thats which a mark up and the cost of them posting it to you. If you buy them in batch
they can come in to close to $200 which is insane , yes the stands and build is nothing amazing, but if it can sit on my desk and not brush into flames then i would be happy
I've just been reading up on the catleap one and it appears to me a LG panel but without the AG coating....
yes all of them seem to be LG panel which are simliar to the ones in dell or apple i think, only different is while those ones are A+ , these will be A or A-. which to be honest if you get one without any dead pixels which a lot of people have , then it looks to be more then work it
HDMI doesn't support 2560x1440
The ports on them are dvi dual link which will support 2560x1440 , i think there are model with other ports, but thats kinda pointless and people where saying when you have more ports it can increase lag or something ?.
