Yewen looks at: Lian Li S80b
Review is done guys, will just need to read through and remove all the band language and porn then it will be ready to post up. :)
Yewen,
Lets see this review - ive got my fingers about to click order, but i want to make sure the fans i have chose make your exacting standards!!!
Lets see it :o Get it out for the boys :o :o
excuse me, im going to hang m'self :eek:
Will this be likely to be today Yewen? I'm holding off pressing the button until I've read your review. Sorry to pester you ;)
Psh.
As long as nobody comes to the door, comes over or asks me to go out then it will be around 5 when I have the review done.
It will be text only with links to the pictures though, as I have not changed anything. :)
Yewen said:
Psh.
Cool, much appreciated.
No its ready to upload and just got to format it from word to the forum software.
Two phonecalls and I am doing it. :p
Its called RMA + Job applications. ;)
I don't live on OcUK, much. :D
Just give me enough time and it will pop up, tempted to just upload the word doc to keep you all happy. Or just suspend you all to keep you of my back, ones easier to do than the other.
Its up, although not sure if its what you are all expecting. :)
Take note of the add me to msn part, happy to chat on there of an evening about the case if you have any specific questions on it.
Enjoy. :cool:
Thanks Yewen, just wondering though....
Did you actually review or use any other fans in the system? And what about the top fan? Have you or are you using it ?
I ran stock Lian Li fans, a set of ADDA ones taken from PC7's, Akasa Ambers, YS Tech own brand fans FD1238 and the Acoutsifan Dustproofs all round. Also used a 80mm Acoustifan clear one.
The top fan is installed at the moment but not turned on as it does nothing for my rig. Only used the fans I had lying about really.
I just like the 7v Ambers in the S80, I get along with them well personally. :)
The fans was the main reason for the delay of my final thoughts.
LOL with you now, sorry i was expecting a mass review on different fans and what works best etc - my apologies :)
Did you check out this review - http://www.pcpro.co.uk/custompc-labs/36/fans/products.html
I know people make fun of pcpro but i needed some advice on fans so i just purchased what they recommended ! Hoping to get noise down to a minimum...
Last question how did you get the volts down to 7? Do you go through mobo/speedfan or controller / wire reducer?
Cheers Yewen
