Unsure what to do with my 4ft one as its pretty old and the previous owners didnt take good care of it.
Really ****ed off now.
I did a massive clean up of the tank yesterday and the day before hoping to get rid of any ich spores that may have been left over. Today my sword tale that I have had since buying the tank is now covered in ich...
I have a done some reading but all the sites give different kind of information to solve the problem. Anyone here had the problem and dealt with it without any fish dying? If so, tell me what you did please.
I have got the tank warming up now. What is it I should be gettin it to? 28 degrees? Any decent treatments you guys have used?
i'm running a vision 180 i think it's 3ft wide bow fronted. it's running a fluval 305 room temperature, but never above 20 deg c. i use ice bottles or ice cubes if need be. it hasn't got fish or turtles in there. there's 4 in there. anyone want to guess what i've got before i ask advice on where to get a particular live food they love?
Axolotl?
Axolotl?
I'm thinking of getting an external filter for my Juwel Rio 180, any recommendations?
I have been looking at the Fluval 406 and the Eheim Professional 3 2075.
Fluval comes with media and no spray bar and is far cheaper.
Eheim may be a bit too powerful for my tank and does not come with media. It's also much more expensive.
I would be looking at adding an external heater also in the near future.
Bloody fish store....
To the guy asking if I have a quarantine tank, yes, a 20ltr tank but I turned it off after not having to use it for a long time. Been up and running a week and half now so not even cycled... Pretty useless now really.
i was just about to say the same. ive got a vision 180 using a 305. you can get a spray bar seperate tho.
Eheim are generally accepted as the pumps with the best build quality.
The 2075 has the electronic pump that you can slow down to a speed that suits you though, just something to bear in mind![]()
I'm using a 305 in a 180L Fluval. Upgraded from the included 205 after it sprang a leak as the 305 is a straight swap on pre-fitted plumbing in the tank and was only a tenner more. Needs cleaning far less regularly than the 205, and the flow is slightly higher.
