Hello all
Had my plants delivered, impressed with the delivery time to be honest (ordered on the weekend)
Question: They've come with lead strips - Are these healthy? Do people here use them? Or do you just dig the plants in to the substrate?
My hornwort was lead weighted down. Was totally fine![]()
Day 23 of cycle, levels seem to be dropping off slowly. I best feed them today though theyve been on a starve why i knocked the nitrite levels down.
Starving established fish for a week while on holiday is one thing.
Starving newly purchased fish, that have often been starved through the fish supply chain, is not good.
Newly purchased fish should be placed a mature quarantine tank that will deal with ammonia and nitrite.
If fish in cycling, you feed the fish to help them recover from the ordeal of being moved and half starved, you then do the daily up to ~75% water changes for ~100 days while your tank matures. You must keep the water safe at all costs.
This is why fishless cycling has been best practice for a decade or more, where it is desirable to maintain ~4ppm ammonia to encourage the ammonia and nitrite processing bacteria to multiply. No water changes usually needed, tank should be fully processing 4ppm ammonia into nitrite within 12 hours within 40 days.
Iv got them well down and under control now with daily water changes of 25-50% depending were my levels are at.
I realllllllly want to find a more efficient way of water changingparticularly the fillibg up part
)Probably evaporating water because 1.) it's an open top tank effectively and 2.) it's a small tank so the water will drop more drastically (or at least seem like it)
Treating the water? Are we talking about testing the water and then treating appropriately?
Evaporation happens in all tanks even the largest and its why auto top up systems exist. On a 125L tank i loose an inch over the course of a week which is 2-3 Liters of water.
For the question earlier about water changes.. I put this http://www.allpondsolutions.co.uk/a...mps/1000-l-h-submersible-water-aquarium-pump/
Into my 25L bucket with a 12mm airline stuck on it
Never thought of that for some reason. May look in to it with an old pump we have!
1000L/h can be taken with a pinch of salt as once your pumping uphill it slows significantly
