- 13 Jun 2011
I did that when i changed mine into a reef tank.
Its very easy to do, just cut the silicone and remove the pump section all together and then fit a hob fiter.
Anothrr way to do it is to cut a slit half way up the rubber hose that comes from the pump so half the pressure goes back into the pump section
Your current Fish tank Setups!
