Caporegime
Yep, as I said in my previous post, always safer to dechlorinate first.I always decholoinate the water I'm putting into the tank, just a couple of drops in each 10l bucket.
How many litres do you change at once?I’d need a lot of buckets for that
My tank was a 180. I changed 50 litres weekly. 6 of those £1 orange B&Q buckets did the trick.I have a 180 litre tank, so about 80-100 but to be fair I don’t just buckets. I use a Python water changer hooked up directly to a mixer tap.
Surely the prime is being fully distributed by you filling the tank.
I just dump Seachem Safe (powdered prime) in the tank and fill the tank straight up out the tap.
As well as the small buckets, I used to use those food grade home brew buckets you can buy as well. They were good, and quite cheap.A hose pipe with a kitchen tape adapter is where its at! or a python but I cant quite justify the cost at the moment. I use a 20l bucket for emptying and time saved vs 10l is worth the back breaking few trips
Has anyone gone down the silk fake plant route? Being a novice I was contemplating mixing some fakes with real or going all fake to begin with along with some stones and wood.
Pay day is looming so hopefully ordering the bits before the end of the month.
