An explosion of snails often means you're feeding too much, or the tank is otherwise a bit dirty. Personally I don't see the issue with them, all they do is help clean up waste and algae.
Feed a bit less, and take them out by hand if you really don't like the look of them (you can bait a jam jar with a bit of lettuce or something to get loads at once).
I certainly wouldn't go pumping chemicals into your tank to try and get rid of them. Lots of rotting snails will do bad things to your water quality, and it could cause problems down the road if you ever want to keep shrimp or other inverts.
