Thanks guys. Might pop St Alban's brach of Maidenhead Aquatics on Saturday to have a look. How long would you need to cycle the tank (say a 125l), from purchase, about 2 - 4 weeks before transfering the fish?
Recently got a tank and decided to go heavily planted. Can anyone recommend a decent way of keeping the glass clean? Not sure what is likely to scratch it.
Very nice
Are you using Co2 or liquid carbon & what ferts do you use?
Just started a heavily planted tank myself, although its still very new the plants are growing very well and I can see a difference every day.
Guys got a bit of a problem. I have a coolie loach. That for the last 4 days have been above the sand in my tank, been lying on his back or side. certainly not his normal behavior as normally (i have 2) they are mostly under the sand.
Is he on his way out and is there anything I can do for him.
I keep a clean tank, regular filter/water changes etc. Had him for about 8 months (both of them) and now this one is showing problems.
Thanks
Don't know what your level of knowledge on fish-keeping is, do you know what a "cycle" actually is?
A lot of people think it's just running the tank without stock for a few days or weeks then dumping the fish in, often to their untimely death!
Size of tank isn't that important; it's just done on a different scale. Generally though, a proper cycle can be 2-4 weeks unless you can put mature media in the filter straight away, eliminating the need for a cycle.
Pretty much all you need to know regarding cycling here
Before you get your new stock, certain species are quite sensitive and shouldn't be added to a brand new tank.
possibly needs a few more plants, + get rid of the 2 rubbish ones the LFS sold me. Still cycling atm so will stock up in about 2 weeks.[/URL]
Getting more plants should help a little bit with the cycling as I can see you are doing a fish-in cycle. One recommendation though: google any plant you want before you buy it. Almost every LFS, big brand or small family shop, sells some plants that aren't aquatic and will just foul your water and make things worse.
