From July 2007 - Asking about a new MoBo/CPU combo from OcUK which was blowing PSU's - MSI K9A Platinum Blowing Power Supplies? - Turned out that the combo of that particular CPU in that particular MoBo was the issue, both worked fine when used separately so OcUK swapped the CPU and all the problems went.
Absolutely no idea how good/bad that PC build was as I have absolutely zero memory of it, so it may not have been mine as I'd been using OcUK from '02-'03-ish (when they were my local PC shop still in small trading "garages" in Fenton) to build PC's for friends, family and work mates etc up until around '10 when I stopped building for folks and even decided to go OcUK pre-built Tyrannosaur V3 for my personal rig rather than building one which is still in use today (with a few GPU upgrades).
Hiya all, bit of a crap 1st post but I've hit a snag building my latest PC. My components are:
MSI K9A Platinum
AMD6000+
HSI HD2900 1GB
Corsair 620W PSU
After building it I tried applying power and after 1sec the power died without any POST beeps to help me (all cpu, system, psu & cooling fans ran during the 1sec of power). I disconnected all the non-essential power sockets (HD's, optical drives, extra cooling fans/leds etc) and tried again with the same result.
Then I removed the Graphics card (in case it was the cause) but the power still died without POST beeps (hoping to get the "No Graphics" 3 beeps). That left the PSU itself, Mobo and chip. I tried a mates PSU but still had the same problem so "Oh crap, it's the Mobo or chip" I'm thinking.
HOWEVER, my mates PSU when back in his PC now refuse's to work either! SO I'm guessing that my Mobo is the cause as it's blowing up psu's (i.e My mates is Kaput - internal fuse? I'm thinking - but mine is still going so mine will probably have a relay) but as it's the 1st major problem I've had in a load of builds that I've had a problem like this I thought I ask if anyone else has had a similar experience?
