Z390 ITX /M-ATX boards, any good ones? 9900K
5 Jan 2004
I have a an Asus Z370I - ITX motherboard and have upgraded to a 9900K obviously I am getting slight VRM throttling when overclocking to 5ghz+
I have recently upgraded my case to a slightly bigger Micro ATX size. Assuming an unlimited budget, what is the best option for a motherboard in ITX or MATX sizing?
It is ashame the 5gigabit ethernet from the ATX board didn't make it's way to this considering the price.
There are some odd choices. Like the weird DIMM.2 slot which will steal PCI lanes from your graphics card. Ideal for all those people who want to run four M.2 drives with reduced GPU bandwidth. As you said, more LAN would have been better, especially as it is missing an expansion slot.
@rIcK
half the price of the Gene with 10+1 phase design
ITX looking damn good too
UK RMA
My basket at Overclockers UK:
Total: £311.04 (includes shipping: £11.10)
ITX is basically a MASTER without doublers due to size , Master has the second best VRMs only out matched by Xtreme and Megs 16 phase design, and Xtreme cools a lot better then the Meg
Gigabyte have generally done a good job of the VRMs on their Z390 boards. The Z390I is 6+2 whilst the Z390M is 10+2 (but that is 10 doubled from 5). The let down on the Z390M is the audio codec. The Gene XI is a beefy 5 phase (spread across 10 stages).
true , Aorus ITX is 6x IR3553 40amp units , Asus Gene is 10x (5 x 2 doubler) IR 3555 60amp (PWM controller is max 8 channels) , Gigabyte mATX is 5 Hi and 5 Low side PPAK (70amps) doubled
Gene uses the better designed IR units like the aorus ITX with bUDGET Matx Gigabyte using the More units plus higher amps but lower quality components handles VRM heat better then most Z390 boards
Gene and Aorus ITX should hit nice ram speeds being 2 DIMM, asus should pip it higher
In my case I use the digital out for audio, so assuming the VRMs are up to scratch and can handle 5ghz 9900k. I imagine the z390M feels like a good choice
Hardware Unboxed picked the MSI over the Gigabyte for best mATX due to it have better board features overall. This is also why I picked it over the Gigabyte (and then sold Odyssey for £28). The MSI has better audio, USB, WiFi and SLI. The MSI VRM is 8+1+1 so not quite as good as the 10+2 on the Gigabyte, but then the Gigabyte has smaller push-pin heatsinks.
mATX @ 5:27
@IT_Troll
gigabyte missing a trick by no releasing an Aorus version of the mATX =/
push pin heatsinks are the best but all Gigabte z390 boards been designed to handle 9900k at stock speeds for 24 hours AVX workload without throttling ... though i wouldn't touch the heatsink during it haha ! and would question the life span haha
His comments at the start. Gigabyte have always focused on 4 Dimms over 2 compared to like ASUS. Gets them ripping but in 3/4 years time when people slamming another 16GB into their system will help in the long run .
Didn't expect Taichi phases to be that bad....
mATX @ 5:27
I ended up picking up the MSI one due to hearing Gigabyte boards had a terrible bios. The overall package feels not as high quality as my Asus Z370 board which had tonnes of really nice touches, from things like included bits, padded io shield and a really slick bios.
Took the opportunity to upgrade my Toshiba 1TB NVME to a 970 evo and put in a couple of Noctua AF14 fans to replace my single 120.
Now I need to find my way around an MSI bios and get my CPU back to 5ghz hopefully without the VRM throttle this time. Anyone know any good MSI 390 or similar overclocking guides?
The following was excellent for Asus boards:
https://youtu.be/95Ujni7-fVM
I wouldn’t say it was great, but MSI did a live stream on Z390 overclocking. I think you might have been better of with the Gene though if you are wanting 5 GHz all core without throttling on a 9900K.
I had all sorts of issues installing Windows 10 on my Samsung 970 EVO nvme, turned out it was mounting the USB part way through the install then giving up after multiple hours fighting it I created a PXE install from a Linux box and managed to get it installing properly.
Regarding the motherboard and overclocking I managed to munge my way through the settings, got it stable at 5.1ghz if I keep giving the cpu voltage, VRMs are not throttling at all which is great news. Prime 95 stable for around 20 mins.
Backed off to 4.95ghz with much lower voltage and decent temps.
