Post Your Home Cine & HiFi Kit...
9 Sep 2008
United Pingdom
Naim and ATC sound signature a bit forward?
I only had the Nait 3, so they were woefully underpowered for the 19s. I ended up with Roskan K3 which is warmer sounding and has a bit more heft.
Indeed it was a bit forward even on the nait 3. I think when I can afford to I'll get the power series.
Right now I have a Roksan K3I on the tweeter, and a K3 Power Amp on the mid/bass, seems to work well, but man the Naim Amp sound is just another level, especially for metal and classical it is without peers.
30 Nov 2003
Probably a bit overkill considering it costs more than the Ambeo plus bar itself, but decided to treat myself as my Ambeo sub packed in and managed to get a trade in with Sevenoaks who will deal with it with Sennheiser :) Been a while since I've had a third party sub so need to play around with the settings unless and recommendations? Got their demo unit at the moment while I test it out and make sure I'm happy before they order a new one.
6 Sep 2016
That's not overkill. Ask if you can borrow SVS PB Ultra 16. ;)
19 Dec 2009
Manchester
How does it sound? These micro kef subwoofers seem to be very highly rated.
30 Nov 2003
I don't have any other sub to compare it against other than the Sennheiser and the Sonos Gen 3 but it absolutely slays both of those. I'm not sure how good it would be in a very large room but in my 7m x 5m it sounds absolutely fantastic. Just the actual sound itself and how much deeper it goes than the other two which makes it feel so much more cinematic. For the size of it, they've engineered something special. Yes it's pricey and I'm sure larger ones for cheaper are better but this fits anywhere, provides fantastic sound and even the wife likes it, so it's a win win.
21 Jul 2008
Outside the asylum
I'm still really impressed with my KC62s, they go crazy low for their size and sound really good for music.
Physics limits how loud they can go (the electronics protects the sub by reducing the output of lowest frequencies as volume increases) but I can't say I've noticed it at normal(ish) listening levels. It might mean it's not as suitable in very large rooms or for AV use if you're trying to damage your house foundations.
6 Sep 2016
"3 . 0 P O S I T I O N I N G
To achieve the best results, the loudspeaker setup should be symmetrical round
your favourite listening position (see Figure 1A – C). We recommend that you
experiment with the position of your loudspeakers – the sound quality will change
depending on the loudspeaker position.
Objects positioned between the speaker and the listening position might negatively
affect sound quality.
The speakers are designed to meet our wide dispersion principle, so they should
NOT be angled towards the listening position, but be positioned parallel with the
rear wall, see Figure 2. By parallel positioning, the distortion in the main listening
area will be lowered and the room integration will be improved. The wide dispersion
principle will ensure that sound is spread evenly within a large area in the listening
room.
3.1 DALI OBERON 5, 7 & 9
The speakers are designed as floor standing speakers and they should ideally be
positioned minimum 20 cm (8”) from the rear wall."
14 Dec 2004
South
Ah, so I'm basically spot on, just need them 2" further forward from the wall
Edit - I've moved them and she hasn't noticed yet....hehehe
