on this mobo theres no where i can change the FSB to match with the x9 multiplaier. so what voltage do i do to get 3.0Ghz and what FSB as as standard im at 1066mhz.
went from 1066 to 1100, then 1150, then 1200, then 1250..... and all was stable with an unlinked memory FSB and voltages on auto.
Then.... went to 1300 and it locks .... so i need to reset CMOS and start again....
Any ideas what i need to up to get from 1250 -> 1300 FSB?
My FSB is 1943 (giving 3.4ghz with a x 7 multi) and my RAM is unlinked at 940. Ive not found unlinking the RAM to cause any performance issues personally.
If you didnt know, the figure you input into the bios is the required speed divided by the multi x 4 (quad pumped). IE 3.4ghz divided by 7 multi = 485 x 4 = 1943 inputed in the bios.
And yes you need to raise the NB volts to 1.5V minimum.
How you manage 1943fsb, anything above 1700 for me and PC wont boot or windows will keep loading forever, tried going over 1800, nothing.........![]()
You tried increasing the voltage of the NB? to 1.5V?
so i need to up the NB voltage only? i left all voltages on AUTO...
im on the latest BIOS... which is the best for overclocking?
0401 bios. 0703 wouldnt let me get much over 1700.
what Vcore and NB Voltage?
Ok then.... well my Heatsink is:- Thermalright Ultra-120 Extreme CPU Cooler
with one of these bad boys
so... i will put the NB to 1.7.... and what should i set the CPU Votlage to? 1.45v's?
Thankyou for all this help, im so grateful.
1.5V + for the NB and for the Vcore, whatever it takes for the CPU to be stable, start at a low Vcore, if the PC resets, crashes or BSOD's then up the voltage abit untill it is stable, run ORTHOS to test for stability, try aim for your 3Ghz first, then do an 8 hours orthos test, well what I would do is test it in orthos for 30 mins, then raise it to say 3.2, test for 30 mins, then 3.4, test for 30 mins and keep going higher, if it survies for 30 mins at say 3.6, then do an 8 hours orthos test, if anything happens like I said above, then lower the frequency abit of even raise Vcore more, 1.55V is about the safe limit for CPU on air btw, I have mine at 1.57 which ends up been 1.47V at load.
You got that in before i could. The pencil mod should get rid of that V Droop, my 1.6V set in the Bios gives me no noticable droop (shown as 1.6v in speedfan.
Btw your bios version should allow for a higher than 1700 fsb![]()
I thought so too, but it dont, havent a clue why :s
Is the pencil mod easy? I think I found a guide once on it, I could not understand it.
See if I could get rid of Vdroop, I might be able to achive 3.5-3.6Ghz.
