No stock cooling
I think voltage will limit the clocks not cooling.
Correct was just curious if you had tried a block on it yet
Good job, they are working on the volt mod for these though shouldn't be too long.
No stock cooling
Right mate hope this info is what you after:
8800GTS 320MB OC score was 10,378
8800GT 512 Single @ stock score was 10,800
2 8800GT 512s SLI OC score was 12,801
No changes to any other hardware/clocks.
I didnt overclock the 1 card as ran out of time and when you disable SLI you have to re-apply the clock in Riva.
I am on the new BETA drivers though but think they're poor for SLI tbh. Also installed the Vista SLI hotfix.
Yeah read that over on XS
What do you have your 8800GT clocked to with getting 15k marks?
My Inno3D 8800GT:
GPU: 700Mhz
Memory: 1000Mhz
Shader: 1700Mhz
13093 3DMarks
That in XP?
If so its a bit low, I got 13073 with 700/1050 clocks but my CPU is at 3.4Ghz.
Had my first play with my Inno3D.
E2160 @ 3.6Ghz
8800GT
Stock clocks = 12033
700/1000/1700 = 12954
For comparison:
8800GTX
620/1040 = 12381
Very Nice. Just got my inno today. What sort of temps you getting with that overclock?
A 8800GT is more than enough to play crysis at medium settings. I have everything on very high expect the shaders at medium and now I'm getting 60fps at 1680x1050 res no aa. AA kills it.
To display the fps in crysis enter r_displayinfo = 1 in the console.
Are you in Vista? If you are then I think, in terms of a comparison, my system has a problem. lol
Edit - looking around the interweb and there seems to be some performance issues with SLI & Vista and the resolution? Await SP1 lol. Hhmm I wonder if the BETA version is any good..
