It's something to do with Nvidia and 8800GTX's and 8800GT's. It's in the first post.
http://forums.overclockers.co.uk/showpost.php?p=10408472&postcount=1
Wow! Your setup runs with a PSU that's rated 380w less than the previous Your electricity bill will thank you.
since when does a psu communicate with a graphics card?there are no data lines, only power.
the difference in his bill will be so small its not even worth mentioning
I meant Antec obviously. It's the only way it would have made sense lol. Just a simple typo
Alright James. I don't know that much about the tech but there is some basic communication between a PSU and the mobo, the PG signal for instance, a mobo can't boot unless the PSU says so (or is it the other way around lol?).since when does a psu communicate with a graphics card?there are no data lines, only power.
Yes it is worth mentioning, why would you want to load a PSU under it's peak efficiency load? Let's all go buy 1000w power supplies for out HTPC's because hey! it doesn't matter right.
Hello, I didn't forget about you guys!
Hello, I didn't forget about you guys!![]()
Hi Mekrel, sorry I didn't reply earlier but I thought the question was a bit off topic, after all it was meant to be a *support* thread for anyone sitting in front of a Quattro/8800GT computer wondering why it wasn't working.Why have you got a 1000w power supply?
I have been using an Antec True-Power Trio 5500w PSU for about a year with no issue
Lol corrected typo!That's one heck of an output!![]()
My pain, your gain!Was looking to buy a quattro 1kw, seems I won't bother....![]()
A lot of people are fine with PSU's on this forum. Just because a few people are having problems with your PSU and GT's doesn't mean that people are misinformed or lacking in knowledge on these boards.I'm surprised to see a lack of accurate wattage information in this thread.
These power supplies were tested by NVIDIA themselves before we released them, and they passed all of NVIDIA's tests. We could not use the SLI logo if we had failed any of their tests. Any Quattro power supply has enough power to run a pair of 8800GTXs without breaking a sweat. There is going to be variation in your individual card, but 8800GTX cards use a slightly different amount of power than the 2900. When you do your rig's Watt calculation, try subbing in a 2900 instead of the 8800GTX and see what happens...
Hello AntecRep,There are many issues that have been brought up in this thread, so let me try to tackle them all.
