- 3 Nov 2004
- UK
Is it just me or is there not a bootmenu on this motherboard?
Nope, and its a PITA. I have three boot drives and it gets really annoying with a USB keyboard timing the del key to get in the bios to change the boot drive.
You could always use a flash drive. Works well.how are you meant to flash from floppy, i formatted as a boot disk and when i try and copy the .bin over the disk is full
) which runs at 2.1v so I'll keep that in mind, cheers
) If you are going raid I think you have to install the Jmicron installation disk, and the Sata drivers (not sure of the order). I didn't set up in raid so I haven't installed any of those drivers. Install the latest drivers linked from this thread. I am sure somebody that set up in Raid can put you right.
