- 4 Aug 2003
- Wicklow, Ireland
I wouldn't put one in my PC unless I knew there'd be a significant improvement to games. If it could add ~5fps to Crysis, I'd pay full price for one now
Chaining multiple PhysX processors is the likely reason.
“When games don't support it?
Just because something is cheap doesn't make it useful.
What nonsense.“
Some games do support it making it useful for some people. It also works in none gaming apps. There are also tons of free games that use it as well.
“id rather just buy a second graphics card and have more fps plus it would take more stress off the cpu at times, like the physx card is supposed to?“
A 2nd graphics card puts more stress on the CPU not take stress off. Depending on your CPU a PPU can give more a FPS boost then a 2nd GPU.
LMFAO! just sold my Physix for £80 on ebay 3 weeks ago, and guess where i found it.....
in the local skip LMAO and it must have worked because he left me good feeback ! LOL !
''RESULT''
and that £80 just bought me the antec p182![]()
been 3 weeks, had positive feeback saying blah blah great item....
“So what games get a better boost from a PPU than SLi?“
Pretty much all of them that support the PPU if you’re to CPU limited to gain benefit from a 2nd GPU.
If you don’t have a super fast CPU a cheap PPU will give more FPS over an expensive 2nd GPU. Of course the best thing to do is get both a PPU and a 2nd GPU for max speed.
Like AMD want to buy Ageia, they have enough problems as it is!
Laugh as much as you want but if you understand how GPU’s work you know its true. Its common sense I shouldn’t need to post examples.
A 2nd GPU or new GPU is useless unless your CPU is powerful enough. In CPU limited games PPU’s have been shown to increase FPS by as much as 30%. In that situation adding a 2nd GPU is not going boost FPS as you dont have the free CPU power.
SLI should never be able to give a 50% FPS boost. That should be impossible if both cards are the same power.
Pottsey you usually debate really well, but this makes you seriously lose some credibility.Its common sense I shouldn’t need to post examples.
Source?Really, like making a killing from the GT shortage ?![]()
Source?
