- 5 Dec 2004
- Horsham, UK
You could always send them yours to test with the RMA! Are you feeling lucky
You could always send them yours to test with the RMA! Are you feeling lucky![]()
I simply did not see a single post where anybody listed the power requirements of their rig and there are misinformed statements in this thread. One of the things about me is I want to be corrected if I'm in error. Please be a friend and don't let me stay misinformed; I'm trying to do the same for Antec users on the web.
The NeoHE/ASUS incompatibility was brought up, and the comparison is actually apt. The Intel power specification had an area that was not strictly defined and an incompatibility occurred as a result. We made a design change to the NeoHE to be more tolerant of timing issues and everything was fine. Antec is one of four companies that ASUS mobos had trouble with. We are barely mentioned in the SPCR news article that explains the issue ASUS had with high-efficiency power supplies here:
http://www.silentpcreview.com/news652.html
Since no Quattro ever made has a problem with any video card ever made that doesn't have an 8800 in its name...
sargatanas gets it:
With the vast majority of 8800 cards and Quattros working together peacefully, there is no need for a recall. We stand behind the product and, if necessary, will send you a modded unit.
I'll keep my fingers crossed for youI can arrange for my PSU and graphics card to be sent to you for testing
I'll keep my fingers crossed for you![]()
Perhaps try the Forceware 169.12 drivers before sending the PSU back.Just had a quick go on The Witcher and Oblivion all max settings at 1280x1024 no slow down, looks like these drivers have saved the expense of a new psu, happy days!!
Hmm, not certain that's the problem. The Antec TPQ850 box says it has 4 12v rails at max 18A each, but it's easily running my X1900XT. That apparently needs a 450W PSU with 30A on the 12V rail. The TPQ box says that the +12V combined max output is 768W (64A).
so why are the 8800gts ok with the 850 quattro? im running the bfg oc 640mb gts and its fine also fine when overclocked i also run my old x1900xt overclocked fine surely the newer cards are supposed 2 pull less power?
If you read it carefully, and check around the other threads mentioned, it's nothing to do with the power that the PSU is capable of supplying. The TPQ850 has been certified by NVidia as handling two 8800 Ultra's in SLI and can also multiple HD2900XT's in Crossfire. It's a startup timing issue with the GTX/GT and some of the TPQ's. It doesn't happen with the Ultra or any other card as far as I can tell.
My reading of what's being said is that the card runs at a lower speed if the PSU doesn't supply a certain amount of power within some unspecified time of starting up. The tolerance allowed varies according to type of graphics card and some PSU's can meet the tolerances and others can't. There is no defined standard for the period - hence the confusion. I've seen several other makes of PSU mentioned in dispatches as having this problem - it's not limited to Antec. If you read the reviews of the TPQ (e.g. hardwarecanucks or custompc), it seems to be very high quality and very stable - which is what persuaded me to buy it in the first place.
I had a similar problem where I was getting 5000 in 3dmark06 and Nvidia contorl panel was showing my PCIE as 1, after installing my NX8800GT using forceware 169.02 drivers. I installed the forceware beta drivers 169.12 and got 12018 in 3dmark06. Give this a go before you buy a new PSU!!
get a full refund and buy a Corsair HX620W and start enjoying your life again!RMA it
Yup I can understand that, I had a real hassle working out the problem myself and as I had just bought a new 8800GT I wasn't gonna hang about so as soon as I found the cause of the issue I legged it out to the shops the very next day and bought the Corsair HX620W. Did it all on the credit card but got my refund for the Quattro before my bill was issued so that worked out well.I was so enjoying it until the point I suffered from this reoccurring nightmare.
