Do you notice any "slight" dithering on the right side of the panel compared to the left? E.g. pull up a white screen and make the comparison.
Nope no difference that I can see and I've tried a load of colours to see if any are better/worse.
I can see that the right side is ever so slightly dithered compared to the centre.
Am I imagining it perhaps.
Actually for example on this OCUK page I cant see any dithering whatsoever, but if I look at a blank white (or very light page) its ever so noticeable.
Think you mean ever so slightly noticable![]()
Thats it
Are there any test pages I can use to check this out?
You can use a DVI to HDMI cable and connect a bluray/hddvd player to it with no problem. Though, if you buy an internal hddvd/bluray drive, the image quality should be just as good, if not better as you can tweak it using ffdshow.
Got on coming Monday, yay.
Just want to check that a X1950Pro will handle this and a 19'' both a native res ok?
For what use?
I tried my old 19" CRT next to my 24" with my desktop spread across both and it worked fine, I dont have room for both but I just wanted to try it.
I have a x1950pro 512mb
320MB GTS's are awful for higher res gaming... sell it and buy an 8800GT. Then get the 24".
Here are some more pics for those that asked, including COD4 @ 1280x800
My photo taking skills really suck and the screen looks blurry on some of the desktop pics, really dont do it any justice
And stealth tape mod
I'd just like to link a few posts from this thread here because anyone new to this thread probably doesn't want to dig around finding them. They mostly include reviews, pics and videos, sorry if I missed any out.
My Review
Front & Rear Pics
My Reflection Test Pic
On Screen Display Walkthrough Video
Video of using it with a PC & Xbox 360
Stand installation video from lbt
Gamesfreak's Unboxing & Desk Pics
Couple of Videos from Dappy
Raikiri's Review
Combat squirrel's Pics
More Pics from Gamesfreak
james.miller's Big Pics
james.miller's Side View Pics
james.miller's Test Pics
Andelusion's Display Setup
lbt's Stand Removal Procedure
Azza's Pics
Lots of Pics from mr x plosion
Big pics from Raikiri
Not yet, the model doesn't exist in the list on the registration form. I sent a question to DGM but haven't got a response yet, I'll let you know if I do.
Just noticed on the left side of the panel (where the screen and the plastic meet. There is a dent in the bezel (plastic frame) approximately half way (i.e. in the middle).
Anyone else has this?
I also noticed in a lot of peoples pictures of their panels showing the OCUk forum, the background colour is much "bluer" than mine.
You guys using default settings or have you calibrated it or something?
mr_x_plosion, fancy uploading your desktop piccy please? Its lush.
