Whats the refresh rate of this monitor ?
I was always told that size isn't important.![]()
60Hz
Ok I just turned my 24" monitor on this morning and was greeted by loads of graphical corruption, I turned off and back on and it was fine, anyone else had a similar problem?
Nope sorry never seen that issue, have my monitor connected to 2 pcs, one on DVI and the other on VGA, neither have done that and both look A ok.
Damm, just realized ive been an idiot. At present running X2 PC's via my 19'' using a KVM, when I could have used one PC via DVI and the other VGA, and just switched between the DVI and VGA outputs using the monitors input selection. Is that what your doing t31os?
Didnt need that KVM switch at all then!
The signal will just be as good, as if it where HDMI - HDMI? Using DVI(from monitor) - HDMI?
Thats right just press one button on the front and it switches to the other input. A few of the pics i posted were taken whilst using the VGA, which goes to show there is no difference over VGA and DVI, well none i could see anyway.
Can someone confirm the above for me aswell please?
I know LCD are not the same as CRT but 60Hz seems abit low , Can't it be set any higher ?
I know I banged on this before, but if anyone could post a picture of this panel with a white clear background. Id be interested to see if there is any shadowing on other panels.
I dont think Im getting any, or whether my eyes are playing games on me, but I just wanted to double check.
Hmm this happened to me after trying to load COD4 at a res that wasn't supported, try setting to 1920x1200 then restart pc, that worked for me.Can anyone shed some light on whats goin on when i use DVI:
This is the first pic, notice the orange menu bar (usually blue) and start menu on the wrong side, if you look at the mouse pointer you can see that the screen is shaking really fast but it's hard to capture on camera. And the tearing on the right palm trees.
Colours are all like inverted or something, and lines goin accross the screen, though the menu bar is blue again.
If i set the resolution to 1920x1200 it goes mental aswell, is there a problem with the monitor? The cable? my 9800PRO?
Everything is fine over VGA.
I just tryed DVI on another monitor and it works fine, though it was at a lower resolution, so im guessing maybe it's the monitor.
