it has got a tilt but it is fairly stiff, you will need to apply firm pressure for it to move.
Just clicked it once backwards, do you know if its goes back anymore? Dont wont to over do it.About £5.99 via courier, not an issue really http://stores.ebay.co.uk/Payperdrop![]()
Why does scratches indicate anything other than they were missed during QC inspection at the factory ? AFAIK there's no evidence at all that OC are sending out returned monitors as new, there are a couple of people who have posted saying that they have found scratches on the casings but that's it ?
Have I missed something![]()
Just recieved it, got it setup using VGA, screen doesn't seem as sharp as my Sony X-Black..
was you using the DVI on the X-Black and are your viewing angles any different than before ?
Odd wonder why it's not so clear ?
The DGM is supposed to hav a VA panel so you should be able to swing around to the left or right and still be able to see the screen without picture deterioration over a standard LCD screen.
I have just tried to log my fault. It's NOT an onsite swap. They collect the monitor for repair. So who knows how long you might be without it for
Going to have to send it back. Not ideal at all.
OcUK said:RMA received on: Not Yet Received.
I'll let you know when mine comes back.
Was picked up about half 2 on Friday.
It Does
- 1920 x 1200 (WUXGA) Optimum Resolution
- 16.7 Million Colours
- 1000:1 Contrast Ratio
- 6ms Response Time
- 500 cd/m2 Brightness
- Viewing Angle (H/V): 180°/ 180° (VA Panel)
- One Digital Input (Supplied with DVI Cable)
- One Analogue Input (Supplied with Analogue Cable)
- Supplied with both Analogue and DVI cables
- Wall Mountable
- Built in stereo speakers
- Warranty : 3 year on-site warranty supplied by Manufacturer (Call DGM direct for all support and RMA issues on 0871 2508000)
After reading the above, this may need changing. Unless on-site warranty covers pick up and repair, which it could do.
